DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
DarrenM
Dec 13, 2016Sr. NETGEAR Moderator
Hello Drxtreme
Is this on the D7000 or the R7300?
DarrenM
- strubinskyDec 13, 2016Guide
Same here: r7300
A New Detection Database is Found. Do You Want to Upgrade to the New Version Now? Current Detection Database Version: v1.46 New Detection Database Version: v1.80 [Yes]
Database could not be downloaded from the NETGEAR server. Please check your Internet connection. - DrXtremeDec 13, 2016Tutor
R7300 DST with latest firmware
