DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
DarrenM
Dec 13, 2016Sr. NETGEAR Moderator
Hello Drxtreme
Is this on the D7000 or the R7300?
DarrenM
DrXtreme
Dec 13, 2016Tutor
R7300 DST with latest firmware
- ElaineMDec 19, 2016NETGEAR Employee Retired
- WaldosrDec 19, 2016Initiate
Updated firmware and I am still having the same issue. Geek squad tried everything from reconfiguring my modem and changing a lot of settings on the router. No luck.
Waldosr Did you try to factory reset? One community user confirmed that fw version 1.0.0.46 fixed the problem.
