DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
DrXtreme
Dec 13, 2016Tutor
R7300 DST with latest firmware
ElaineM
Dec 19, 2016NETGEAR Employee Retired
- WaldosrDec 19, 2016Initiate
Updated firmware and I am still having the same issue. Geek squad tried everything from reconfiguring my modem and changing a lot of settings on the router. No luck.
- ElaineMDec 19, 2016NETGEAR Employee Retired
Waldosr Did you try to factory reset? One community user confirmed that fw version 1.0.0.46 fixed the problem.
- strubinskyDec 19, 2016Guide
ElaineM: I did and had even reloaded the firmware. I was already at the latest version but the 7300 started to become very unstable which motivated me to reload the firmware to be sure that no bit of the firmware had gone sour.
