DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
ElaineM
Dec 28, 2016NETGEAR Employee Retired
DrXtreme The firmware you received does not contain the security vulnerability fix. The latest firmware released on this site fixes that.
strubinsky
Jan 08, 2017Guide
I venture to disagree!
I received my replacement, updated to V1.0.0.46_1.0.13
and received:
| Detection Database Update Assistant | |
| A New Detection Database is Found. Do You Want to Upgrade to the New Version Now? | |
| Current Detection Database Version: | v1.46 |
| New Detection Database Version: | v1.80 |
