DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
Todd1981
Jan 14, 2017Initiate
This is ridiculous. You can't post the fix to this? You have to secretly message everyone or pass it off to geek squad who can't fix it either. I paid 300 for this junk that supposedly had a ddwrt port which obviously doesn't.
ElaineM
Jan 16, 2017NETGEAR Employee Retired
We follow certain procedures in providing the beta firmware.
I apologize for any inconvenience. Anyhow, I have sent a copy to your inbox.
- dickiepageMar 30, 2017Aspirant
I have the same problem. Is there a fix?
- strubinskyApr 04, 2017Guide
This version has both the security patch and the update feature implemented, Elaine?
- mfulsom07Apr 03, 2017Aspirant
Yes I downloaded a few minutes ago. It has update thanks for the reply.
