DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
SlayerBRK
Jan 21, 2017Aspirant
Same issue, already running firmware version V1.0.0.46_1.0.13 and have done a factory reset.
- wvmdJan 24, 2017Aspirant
Hi - I am also experiencing this issue.
- JorbeMar 18, 2017AspirantI would like the beta too. Thanks!
- ElaineMMar 20, 2017NETGEAR Employee Retired
scoobygolfer You can follow the instructions on this link to upload the firmware.
Once you have uploaded then you may update the QoS database by clicking "Update Now".
