DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
SlayerBRK
Jan 21, 2017Aspirant
Same issue, already running firmware version V1.0.0.46_1.0.13 and have done a factory reset.
- wvmdJan 24, 2017Aspirant
Hi - I am also experiencing this issue.
- JorbeMar 18, 2017AspirantI would like the beta too. Thanks!
- ElaineMMar 20, 2017NETGEAR Employee Retired
scoobygolfer You can follow the instructions on this link to upload the firmware.
Once you have uploaded then you may update the QoS database by clicking "Update Now".
- strubinskyMar 21, 2017Guide
It's quite some time now. When will there be a version that combines both the security vulnerability fix of the latest official firmware PLUS the database update issue? The security vulnerability is not fixed in the beta that you provide, right? And if we update the beta/fix from this thread with the latest official version we lose again the update database capabilities. But if we update our current firmware with the one that you provide, we are again vulnerable? Right?
Please enlighten us, Elaine.
with kind regards
g strubinsky
- ElaineMMar 27, 2017NETGEAR Employee Retired
spaceboyusa Thank you for the confirmation.
- tyaddyApr 04, 2017Aspirant
I am having the same issue with my R7300 DST router. Please assist.
Firmware Version
V1.0.0.46_1.0.13Current Performance Optimization Database on Router Version: v1.46,1.0.26 Release Date: 2015/03/08
