DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
SWKerr
Feb 07, 2017Aspirant
I have the same problem where Current Performance Optimization Database on Router is stuck at Version: v1.46,1.0.26
Is there a soltution for this issue. Currently I have found that the QoS feature is usless with the current setup. Setting a priory for a PC or device is pointless. The lowest PC on the priorty list will get all the bandwith compared to a highest Xbox One.
- WesSFeb 10, 2017Aspirant
Thanks. The performance database update worked.
- hcschaubFeb 22, 2017Aspirant
Thank you for the update. I succesfully update the firmware and QOS database. My question - after updating the database, I reinstalled the lastest firmware and have had no issues after installing on Jan 9, 2017. (Firmware Version V1.0.0.46_1.0.13) Why would this be a bad idea?
Sorry Feb 9, 2017 I installed the update, downloaded QOS Database, and reinstalled the current firmware.
