DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
SWKerr
Feb 07, 2017Aspirant
I have the same problem where Current Performance Optimization Database on Router is stuck at Version: v1.46,1.0.26
Is there a soltution for this issue. Currently I have found that the QoS feature is usless with the current setup. Setting a priory for a PC or device is pointless. The lowest PC on the priorty list will get all the bandwith compared to a highest Xbox One.
- SaythisFeb 16, 2017Aspirant
Hello, I am also experiencing this and was wondering if I could use the beta as well? Thank you!
- ElaineMFeb 22, 2017NETGEAR Employee Retired
We advise that you update your router to the latest release because it has the fix for the security vulnerability issue.
- hcschaubFeb 22, 2017Aspirant
Just to confirm
1. Download the latest firmware, unable to update the QOS Database
2. Requested older version, installed, was able to update the QOS Database
3. Downloaded the lastes firmware, installed, reboot, - working with no issues for 21 days.
After you install the update, download the QOS Database, we need to return to the lastest firmware - Firmware Version
V1.0.0.46_1.0.13
You just needed the beta to install the QoS database and then upgrade it to the latest fw.
Ok, that's what we did and all working fine - Thank you for your quick response and help.
