DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
- ElaineMFeb 22, 2017NETGEAR Employee Retired
We advise that you update your router to the latest release because it has the fix for the security vulnerability issue.
- hcschaubFeb 22, 2017Aspirant
Just to confirm
1. Download the latest firmware, unable to update the QOS Database
2. Requested older version, installed, was able to update the QOS Database
3. Downloaded the lastes firmware, installed, reboot, - working with no issues for 21 days.
After you install the update, download the QOS Database, we need to return to the lastest firmware - Firmware Version
V1.0.0.46_1.0.13
You just needed the beta to install the QoS database and then upgrade it to the latest fw.
Ok, that's what we did and all working fine - Thank you for your quick response and help.
You're very welcome!
- ElaineMMar 01, 2017NETGEAR Employee Retired
You're welcome!
There's no definite timeline that I can provide but our engineers are aware of this.
- ElaineMMar 02, 2017NETGEAR Employee Retired
oZo61 You're very welcome and thank you for providing an update.
- TacoswamperMar 02, 2017Aspirant
I need a copy of the Beta too. Is there any word on a release date for a full fix? No offense to you Elaine you're doing fine, but this isn't the kind of support I'd expect from Netgear on one of their higher end products.
Tacoswamper I cannot get any definite date as to when but I have sent the beta to your inbox.
