DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
spaceboyusa
Mar 22, 2017Aspirant
Ditto. Can I get into the beta? TY.
Rob
ElaineM
Mar 24, 2017NETGEAR Employee Retired
Can somebody confirm if firmware 1.0.0.52 fixes the QoS database and the security vulnerability issue?
- spaceboyusaMar 25, 2017Aspirant
I just loaded the 1.0.0.52 firmware, straight from .46/did not load what you sent me via PM, and after doing so was able to refresh the QoS to version 1.80. Woohoo! Thanks for the fix!
-Rob
