DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
ElaineM
Jan 16, 2017NETGEAR Employee Retired
We follow certain procedures in providing the beta firmware.
I apologize for any inconvenience. Anyhow, I have sent a copy to your inbox.
dickiepage
Mar 30, 2017Aspirant
I have the same problem. Is there a fix?
- strubinskyApr 04, 2017Guide
This version has both the security patch and the update feature implemented, Elaine?
- ElaineMApr 04, 2017NETGEAR Employee Retired
Yes.
- mfulsom07Apr 03, 2017Aspirant
Yes I downloaded a few minutes ago. It has update thanks for the reply.
- tyaddyApr 04, 2017Aspirant
Thank you. Worked like a charm
