Out_side's avatar
Out_side
Follower
Mar 22, 2023
R7450 Error Code 8066
Cannot login I'm getting an Error Code 8066 on my iPad 8th generation, IOS Version 16.31
  • FURRYe38's avatar
    Can you log in using a PC and web browser?
    Is this using the Nighthawk App on the pad?
  • michaelkenward's avatar
    michaelkenward
    Is that using the Nighthawk app? (Hard to tell with so little detail.) What tgrws that error code?
    You can also get into the browser graphical user interface (GUI) using a browser on your mobile device.
    • Sign into the router's wifi
    • Open a browser
    • Try to access routerlogin.net or 192.168.1.1
    It might also help if you told us about the modem/gateway/ONT  that connects your router to the Internet.
