CrazyCharlie
Sep 14, 2015Aspirant
r7500 Bricked After Latest Firmware Update from Dashboard
Hello. I bought my r7500 on May 28, 2015 and it's been working great. This evening I saw that the network control panel showed a new firmware update was available. I'm connected via ethernet an...
- Sep 15, 2015
You could try this process here;
http://kb.netgear.com/app/answers/detail/a_id/22688
When you were attempting to ping the router had you set a static IP at the PC? If not the PC may not have been on the same subnet and pings would simply fail for that reason.
You should still try contacting Tech Support and explain that you have a hardware issue, if you have not already registered the router then please use this link;
Babylon5
Sep 15, 2015NETGEAR Employee Retired
