DKinSwitzerland's avatar
Dec 11, 2015
R7500 'Limitations' in Access Point Mode (Nighthawk X4 r7500 ac2350, r7500v2)
When Configured in "Access Point Mode" (or when manually configured as a swtich by turning off DHCP), the r7500 has many limitations.   A better know example is that the r7500 in "Access Point Mode...
  • DKinSwitzerland's avatar
    DKinSwitzerland
    Dec 30, 2015
    Update: limited failover protection.
    Netgear engineers seem to have identified the "problem" and written an updated firware that allows limited failover protection (using the WAN and a LAN port).  Awesome, thanks!  Now the WAN and LAN ports R7500 should function more like the R7000 while in Access Point Mode ("switch-like" with limited "failover")
    It is nice to know that NetGear did get the message and took the issue seriously and fixed it.  While it was a bit more painful than necessary to get the feedback through to the design team so they could make the change (I think most customers would have given up long before me),  I am confident that NetGear does listen to their customers needs and is committed to getting their products to work in the way their customers need.
    Thanks again.
    DK
