willco007's avatar
willco007
R7500 maximum file size corrupting backup drive
I purchased a R7500 recently to use with Apple Time Machine; only after I bought it did I find the FAQ stating it only supports files under 500 GB :smileyindifferent:.  I have a computer whose backup...
  • willco007's avatar
    Jan 07, 2016
    I've since contacted support and they were as helpful as you might expect. :smileyfrustrated:  But they did confirm the file size limit with no ETA on a fix.  This is frankly a critical bug and renders Time Machine support (a feature they adversise all over the site) useless.  Not impressed and it will be going back.
