dunkens's avatar
dunkens
Apprentice
Jan 15, 2017
r7500 slow upload speed
Hi
Using a r9000 acting as a router , wired to the ap that is the r7500 placed in the second floor of the house
But upload speed is crazy
1.89 Mbps
Any idea how to resolve this problem ?
Download speed is good
1.89 Mbps to 2,5 Mbps
Running on the V1.0.0.94
  • Using a cable directly to the r7500 :
    Download: 394,19 Mbps
    Upload : 200,22 Mbps
    Using the same cable that is connected to the r7500 , but using in in the computer it gives:
    Download: 430,72 Mbps
    Upload: 230,45 Mbps
    Length of cable , 50 meters
    Connecting the r7500 directly to the fiber converter , cable length 0,5 meters
    It gives the same speed as the first test posted in this thread .
    So dont think its a "cable" problem , did call netgear and they put up an case on it , so i hope it goes to an RMA
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi dunkens,
    1. What is the speed of the device when connected directly to the R9000?
    2. How long is the cable from the R9000 to R7500?
    3. Bring the R7500 closer to R9000 and use a short cable and check the speed.
    • dunkens's avatar
      dunkens
      Apprentice
      Upload: 230,45 Mbps
