William10a
Jan 21, 2017Master
R7500 x4 vs the r7800 x4s
Which of the two is best for the home I know that x4s version has a faster processor and double the band witdh on the 5 ghz ac band. However does that alone different really matter in a 1100 square h...
- Jan 22, 2017
What is this 71 mW limit you speak of?
While the R6400 will probably be fine, I have a soft spot for the R7000. The R7000 has really good third party firmware support should you ever decide to go that route.
William10a
Jan 22, 2017Master
So the limit 71 wmatt should be enough and are the r6400 or r7000 the right chooses for the job?
TheEther
Jan 22, 2017Guru
- William10aJan 22, 2017Master
71 mwatt is the rf power level than a router is limited too by the FCC right now under its rules my old wndr3400 v1 is at 521 millwatts well over the new limit with a top limit of 1000 mwatts at the radio interface level but the transmitter has its limits before it overloads and its signal to ratio noise causes problems or burns out. I beleave the the R7000 is the best choice.
