Flasher
Dec 13, 2016Star
R7500v1 also affected by vulnerability
So I know, that Netgear doesn't care about the R7500v1 at all anymore, but I wonder if I still will get a fix for this vulnerability. Otherwise I'm returning this thing right away.
- Dec 16, 2016
Hi All,
The Security Advisory for VU 582384 is regularly updated.
For more information, please see the link below.
mdgm-ntgr
Dec 13, 2016NETGEAR Employee Retired
Which firmware are you running on your R7500v1?
So you've run the check to see if your unit is vulnerable?
The Security Advisory states "NETGEAR is continuing to review our entire portfolio for other routers that might be affected by this vulnerability. If any other routers are affected by the same security vulnerability, we plan to release firmware to fix those as well."
- Wilco_MunsDec 14, 2016Aspirant
I'm also using a R7500 Nighthawk X4 (AC2350). The firmware is V1.0.0.94.
The check's also indicate this type is affected. The R7500 is mentionedon http://www.sj-vs.net/a-temporary-fix-for-cert-vu582384-cwe-77-on-netgear-r7000-and-r6400-routers
as affected device.
- mdgm-ntgrDec 15, 2016NETGEAR Employee Retired
That link shows a 3rd party website's opinion as to what's affected not the findings from our testing.
The list of known affected devices in the Security Advisory does not include the R7500.
- ElaineMDec 16, 2016NETGEAR Employee Retired
Hi All,
