Flasher
Dec 13, 2016Star
R7500v1 also affected by vulnerability
So I know, that Netgear doesn't care about the R7500v1 at all anymore, but I wonder if I still will get a fix for this vulnerability. Otherwise I'm returning this thing right away.
- Dec 16, 2016
Hi All,
The Security Advisory for VU 582384 is regularly updated.
For more information, please see the link below.
Wilco_Muns
Dec 14, 2016Aspirant
I'm also using a R7500 Nighthawk X4 (AC2350). The firmware is V1.0.0.94.
The check's also indicate this type is affected. The R7500 is mentioned
on http://www.sj-vs.net/a-temporary-fix-for-cert-vu582384-cwe-77-on-netgear-r7000-and-r6400-routers
as affected device.
mdgm-ntgr
Dec 15, 2016NETGEAR Employee Retired
That link shows a 3rd party website's opinion as to what's affected not the findings from our testing.
The list of known affected devices in the Security Advisory does not include the R7500.
