letexier
Apr 13, 2017Aspirant
R7500v2 gigabit speed via LAN
I have a brand new R7500v2 router and new gigabit internet. But when I connect to the internet through the router I do not get gigabit speeds. When I connect directly to my modem I get closer to ...
- Apr 13, 2017
Started poking around a bit more and decided to hit the "reboot" within the Netgear genie and it seemed to change something with the speeds.
So call this resolved and if anyone has the same problems, update firmware and once you've done that log into the router and hit the 'reboot' button in the settings to reboot the router.
My speeds are close to gigabit now when I'm LAN connected. On 5Ghz its at ~218/21 which isnt too bad.
letexier
fmiranda
May 09, 2017Aspirant
So the R7500v2 can handle gigabit intenet speeds? I have that wifi router and will get Gigabit internet this week. I guess I don't have to upgrade my wifi router then?
A lot of people said that only the R7000 and the R7800 could handle gigabit Internet - I guess its not true then..
- letexierMay 09, 2017Aspirant
Yes it can do gigabit speeds. I'm getting the speeds I should via LAN cable.
- fmirandaMay 09, 2017Aspirant
Would the R7800 perform any better than the R7500v2? Also according to a few websites, the Wan-to-Lan speeds are much better on the old R7000. Does it make any sense?
I don't know... I haven't tested. I'm sure you could always buy/return if you purchase through Amazon or some place with a good return policy.
