nickat1's avatar
nickat1
R7800, /23 LAN mask. Config advice to get DHCP pool & GW at either ends of the subnet. Voxel f/w.
Hi, I have an R7800. I've configured a /23 mask for the LAN. I would like my router ip/gateway to be in the bottom half of the subnet and the DHCP pool to be in the uppper half. In the GUI I can only put the router IP and DHCP pool in the same /24 subnet. Can I edit the DHCP config from the CLI, and if so, what commands do I need to use. I've tried looking for a command line reference but I can't find anything for the R7800.
I'm running a Voxel firmware, R7800-V1.0.2.97SF.
Thanks.
