m0a0k0s
Jan 27, 2017Aspirant
R7800 5ghz disappearing for a short time
R7800 randomly drops the 5ghz band and restore it back. "Select wifi network" window appears on my iPad 4 (ios 9.3.5), but when I choose "cancel" button it immediately reconnect to wifi network and ...
- Mar 05, 2017
Hi m0a0k0s,
If that is the case, this means the router is working fine and it has something to do the devices that does not stay connected to 5Ghz. You might want to update the iOS version or contact Apple.
JamesGL
Jan 30, 2017NETGEAR Employee Retired
Hi m0a0k0s,
Try changing channels of the 5Ghz network. If still the same, reset the router.
m0a0k0s
Feb 23, 2017Aspirant
I've just discovered next thing in router log:
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:36
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:33
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:12
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:09
It happened just in time when my iPad lost network again and it's the iPad MAC address.
I'm sure I didn't have those records in log before I turned on SSID broadcasting.
I never change connection setting on iPad since I configured it with new router. iPad uses static IP address.
Moreover there's no way in IOS to explicitly change security options on already registered network, except unregister the network completly.
Also I have "Turned on Access control" with "Allow all new devices to connect" checked.
