m0a0k0s
Jan 27, 2017Aspirant
R7800 5ghz disappearing for a short time
R7800 randomly drops the 5ghz band and restore it back. "Select wifi network" window appears on my iPad 4 (ios 9.3.5), but when I choose "cancel" button it immediately reconnect to wifi network and ...
- Mar 05, 2017
Hi m0a0k0s,
If that is the case, this means the router is working fine and it has something to do the devices that does not stay connected to 5Ghz. You might want to update the iOS version or contact Apple.
m0a0k0s
Feb 23, 2017Aspirant
I've just discovered next thing in router log:
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:36
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:33
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:12
[WLAN access rejected: incorrect security] from MAC address ..., Friday, February 24, 2017 15:07:09
It happened just in time when my iPad lost network again and it's the iPad MAC address.
I'm sure I didn't have those records in log before I turned on SSID broadcasting.
I never change connection setting on iPad since I configured it with new router. iPad uses static IP address.
Moreover there's no way in IOS to explicitly change security options on already registered network, except unregister the network completly.
Also I have "Turned on Access control" with "Allow all new devices to connect" checked.
JamesGL
Feb 26, 2017NETGEAR Employee Retired
Hi m0a0k0s,
Do you have other devices you can use? This is just to check if the same behavior happens using a different device
- JamesGLMar 01, 2017NETGEAR Employee Retired
Hi m0a0k0s,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.- m0a0k0sMar 03, 2017Aspirant
Hello. I’ve cheked log records and there are no records with “WLAN access rejected”, except today when I came here. This error appears only for iPad4, iPhone constantly switches to 2.4ghz but there are no messages in the log. Other devices that connected to router are iPod Touch (iOS7), iPad Air 2 (iOS 10), appleTV, smart tv, notebook. No errors in log. All configured to use single band, so no switching. It seems that iPad Air 2 doesn’t have this problem, at least no "Select wifi network" message and no errors, but different iOS version.
- JamesGLMar 05, 2017NETGEAR Employee Retired
Hi m0a0k0s,
