m0a0k0s
Jan 27, 2017Aspirant
R7800 5ghz disappearing for a short time
R7800 randomly drops the 5ghz band and restore it back. "Select wifi network" window appears on my iPad 4 (ios 9.3.5), but when I choose "cancel" button it immediately reconnect to wifi network and ...
- Mar 05, 2017
Hi m0a0k0s,
If that is the case, this means the router is working fine and it has something to do the devices that does not stay connected to 5Ghz. You might want to update the iOS version or contact Apple.
JamesGL
Feb 26, 2017NETGEAR Employee Retired
Hi m0a0k0s,
Do you have other devices you can use? This is just to check if the same behavior happens using a different device
JamesGL
Mar 05, 2017NETGEAR Employee Retired
Hi m0a0k0s,
