BoDEAN
Dec 02, 2016Apprentice
R7800 and DFS Channels usage
Just installed a Netgear R7800. Seems like the most recent FW supports DFS channels. Can someone tell me the pros/cons of using these channels, say over 48, 149, or 161? I live downtown Chicago, so t...
- Dec 02, 2016
DFS is designed to allow Wi-Fi to coexist with radar systems. Radar systems take priority so I would think to avoid using DFS channels unless there is no other choice or there are no radars around.
HT160 uses a lot of spectrum and will likely not be robust against interference. Unless you have a HT160 client (I don't think any exist; Apple very unlikely), there's no reason to use it.
BoDEAN
Why would netgear openup the DFS channels in the US then
