GuyBrush85's avatar
GuyBrush85
R7800 and Nest Protect
Hello, I have a netgear R7800 on the latest firmware (.28) and I'm having issues with Nest Protect. Before buying and installing the Netgear I had my (now modem), in router mode and Nest Protect wo...
  • GuyBrush85's avatar
    Apr 05, 2017
    Well the replacement Nest unit came and I managed to get it all connected up straight away. Couldn't say why the old unit worked perfectly fine before I moved to the Netgear!
    Thanks for the help and suggestions everyone.
