GuyBrush85
Mar 27, 2017Aspirant
R7800 and Nest Protect
Hello, I have a netgear R7800 on the latest firmware (.28) and I'm having issues with Nest Protect. Before buying and installing the Netgear I had my (now modem), in router mode and Nest Protect wo...
- Apr 05, 2017Well the replacement Nest unit came and I managed to get it all connected up straight away. Couldn't say why the old unit worked perfectly fine before I moved to the Netgear!
Thanks for the help and suggestions everyone.
GuyBrush85
Apr 03, 2017Aspirant
Tried everything barring taking the password completely off 2.4, which I don't even want to do for testing purposes. Have passed back the info to Nest to see what they can do, maybe RMA my Protect and see if the problem is on another one. That or I need to take my nest to someone elses just to test it on another router, but it seems to be a compatability issue by the looks of it.
I still have a case open with Netgear, but have not yet recieved any response on that.
Apr 03, 2017Guru - Experienced User
Aside doing a quick test with WPA disabled to see if the NEST would connnect then re-enabling WPA, you could test a different model or Mfr router.
This seems to be a NEST issue and would start there.
Good Luck.
