efyzz
Jan 20, 2026Aspirant
R7800 antenna numbering
Hello, I would like to connect external 2.4GHz antennas to my R7800 – Nighthawk X4S AC2600. I'm wondering why the four antenna ports are numbered 1, 1, 2, 3 (and not 1 to 4). Is there any ...
efyzz
Jan 21, 2026Aspirant
Thanks for your answers!
I already played around with repeaters, additional access points and AVM (Fritzbox) mesh components. Nothing was satisfactory... My mobile devices had always problems when moving from one "AP" to another. What I did not try is a Netgear mesh. Maybe that works better than AVM, but I don't believe in it.
As said before, with my 4 antenna solution I have great coverage, so the coax cables (which are only a few meters long) are not the problem.
The question is actually, why are the ports of R7800 numbered 1,1,2,3? There must be a reason. ;)
As far as I understand, the firmware does nothing about antenna management. It's all done by the WLAN chipset, isn't it?
