Naks
Jan 19, 2017Aspirant
R7800 Bridge mode don't work
Hello, I bought a R7800 (firmware 1.0.2.20), i link my computer and the router with ethernet, and i try to use the bridge mode on the Wifirst's public router. But when i set the bridge mode the rout...
- Jan 26, 2017
None of our home routers supports such feature.
I'm not sure if 3rd-party firmware will help.
Naks
Jan 22, 2017Aspirant
Yes but when my router switch to bridge mode i cant access to the routerlogin.com page and my PC dont detect the router on the ethernet port.
ElaineM
Jan 23, 2017NETGEAR Employee Retired
When the router is set on bridge, it's normal that you will no longer be able to access it through routerlogin.net.
You will need assign a static IP address by selecting "Use Fixed IP Address". Make sure that the IP address that you will assign should be in the same range of the main router.
- NaksJan 24, 2017Aspirant
Ok, because i had access to the page routerlogin.net a little time like 45s in bridge mode, it's why ithink it was possible to go on it.
i try what you propose, but it's don't work. Maybe because i'm not configuring the bridge mode correctly, i'm not a pro :/
I tried with the ip adress shown on my phone when he is connected to the main router for static IP.- ElaineMJan 24, 2017NETGEAR Employee Retired
Just follow the steps on how to set it as bridge and do not forget to select "Use Fixed IP Address".
Once done, you should be able to access it through that IP address that you have just assigned.
Let us know any update.
- NaksJan 26, 2017Aspirant
Yes i did, but now windows say: "Unidentified Network" when i'm connected with ethernet on the router in bridge mode.
Maybe because i don't write the right SSID ?
