ferret141
Jun 09, 2017Aspirant
R7800 cannot be seen by HP T120 printer (wired and wireless)
I have purchased a HP T120 Printer. It cannot see my R7800. Whether wired or wireless. When trying to connect wirelessly I can see the neighbour's router on the printer but not mine. I have also ra...
- Jun 10, 2017
Drivers are already loaded, even though they do not need to be.
I am now able to connect it via wifi. The printer did not like the router sitting in channel 13. Switched to channel 1 and it could find the network. Printed successfully too.
I have not figured why it doesn't connect via LAN
netwrks
Jun 09, 2017Master
Dis you load the printer's drivers on your desktop (or whatever you are using)?
- ferret141Jun 10, 2017Aspirant
- netwrksJun 11, 2017Master
Yes, printers will look for 2.4ghz non-overlapping channels - 1,6, or 11.
- ferret141Jun 11, 2017Aspirant
What I found strange was that my other HP printer, a consumer printer, was able to see the network fine despite being on channel 13.
I'm still trying to figure out why I couldn't connect via LAN though.
