MasterOfArts
Jan 23, 2017Aspirant
R7800 customer query and introduction
Hello All, Firstly I would just like to say I think the R7800 is a fantastic product. Only downside to me is the UI is a bit slow. I was always a netgear customer in the past not only in my w...
- Jan 30, 2017
Hi MasterOfArts,
Yes, you can still use the other ports of the router.
MasterOfArts
Well Lee the force must be strong with you dood cos the only 2 things for me to do is switch off the 20/40 and QOS. The rest I generally do as standard m8 now re DHCP reservation etc and even CAT 7 cables. I also have a mycloud NAS plugged in via ethernet cable and im a gamer so I have to open up a few ports sadly.
Thanks very much for the pointers and I will get QOS and 20/40 off now and have a look at the switch you use, I am one of those guys if I get a netgear router ill get matching switch etc... Bit of OCD in me.
All the best,
MOA.
All the best,
MOA.
