XRay_
Aug 08, 2022Aspirant
R7800 Firmware v1.0.2.90 loses internet connection during Samsung TV streaming
During straming with a Samsung TV, internet connection continues to get lost. Must reboot TV.
Any solution?
Is the TV wireless connected when streaming?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?How is the wireless setting and advanced wireless settings configured on the router?
What is the distance between the router and TV?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
How is your TV connected to the router?
I find wifi to be flaky. My strategy is to use Powerline Ethernet to plug the TV into a wired connection.
You say nothing about what happens beyond "internet connection continues to get lost". As well as the questions from FURRYe38, Is that just the TV or everything?
