albradford
Jun 07, 2018Guide
R7800 Firmware Version 1.0.2.52 What happened to all the device names?
I just performed the updgrade to 1.0.2.52 (6/7/2018)
All the device names are blank. What happened? I rebboted a few times.
- Jun 07, 2018
Went back to firmware version V1.0.2.46.
The device names came back.
I'll be happy when the interns stop writing the firmware updates.
microchip8
Jun 07, 2018Master
Use the search, there are a few threads about it. Basically, known problem that needs to be fixed by NG
michaelkenward
Jun 08, 2018Guru - Experienced User
Indeed:
R7800 Device names disappeared after update - NETGEAR Communities
- endlessenderJun 09, 2018Aspirant
I also get horrible bufferbloat with 52 that is not present with 46. I 've swapped back and forth and can easily reporduce the reults. So, for now, I've reverted back to 46. I can't believe how bad 52 is overall.
