albradford
Jun 07, 2018Guide
R7800 Firmware Version 1.0.2.52 What happened to all the device names?
I just performed the updgrade to 1.0.2.52 (6/7/2018)
All the device names are blank. What happened? I rebboted a few times.
- Jun 07, 2018
Went back to firmware version V1.0.2.46.
The device names came back.
I'll be happy when the interns stop writing the firmware updates.
michaelkenward
Jun 08, 2018Guru - Experienced User
microchip8 wrote:
Use the search, there are a few threads about it. Basically, known problem that needs to be fixed by NG
Indeed:
R7800 Device names disappeared after update - NETGEAR Communities
endlessender
Jun 09, 2018Aspirant
I also get horrible bufferbloat with 52 that is not present with 46. I 've swapped back and forth and can easily reporduce the reults. So, for now, I've reverted back to 46. I can't believe how bad 52 is overall.
