StaticFree's avatar
Nov 23, 2020
R7800 in AP mode- cannot access web console from another subnet
I set up the R7800 router in Access Point (AP) mode and have given it a static ipaddress.  Also disabled DHCP.
It is connected to my network on a VLAN with subnet ipaddress 192.168.100.4.  From my private subnet with different ipaddresses in the 192.168.1.xxx range, trying to logon to the Netgear R7800 fails with the error message:
404 Not Found
This server does not support the operation requested by your client.
I've searched the internet for this problem and see it has been a problem with just about all Netgear devices firmwares for many years back and to this date nothing has been done to fix it.  It seems that in the Netgear firmwares they coded a module that will not allow a client (like a Windows 10 PC) with a different subnet ipaddress from the R7800 subnet ipaddress to access the web server GUI html.  Login when the Windows PC is on the same subnet ipaddress as the R7800 works fine.
I tried updating to the latest firmwares including Voxel's latest firmware R7800-V1.0.2.80.5SF and the problem still exists.
Is there anyone at Netgear that can finally escalate this issue and get it fixed?
    • StaticFree's avatar
      StaticFree
      Tutor
      Whether or not this issue is caused by disabled functions while in AP mode this is a bug that should be fixed by Netgear.  I can't believe they still have not addressed this issue.
      • antinode's avatar
        antinode
        Guru
        > a static ipaddress. [...]
           Ok.
        > [...] Also disabled DHCP. [...]
           Pointless?  Selecting "AP Mode" should do that automatically.
        > 404 Not Found
           What, exactly, is looking for what, exactly, (without success)?
        > I've searched the internet for this problem and see [...]
           Thanks for the helpful links.
        > get it fixed?
           I'd expect so, but an actual support case is more likely find its
        way to any such person than a complaint here is.
           I don't generally deal with local VLANs, so I know nothing, and I
        can't see what's actually happening in your case, but I wouldn't expect
        LAN operations between different subnets to work without involving a
        router.  Hence, it's not obvious to me that there's actually a problem
        (with the router) to be "fixed".
        > mode this is a bug that should be fixed by Netgear. [...]
           I doubt that the cause (bug or other) is a "disabled function"; more
        likely, I'd say, it's some incompatibility between the expectations of
        the relevant HTML and those of the user.
        > [...] I can't believe they still have not addressed this issue.
           That's easy to explain.  How many users of this consumer-grade device
        do you think might be affected by such a problem?  With the backlog of
        more common bug-reports which Netgear must have, I'd be amazed if
        anything like this ever bubbled to the surface.
