mrezrider's avatar
mrezrider
R7800 losing internet after modem reconnection
My ISP has Asus modem/router that I still use while it has/routes IPTV .. R7800 is connected and in router mode .. all is good until modem reconnects every 24h .. after that R7800 gives wifi .. says internet is ok .. but no worky worky .. I reboot R7800 and than it gives internet to all devices connected .. what could be the problem? why on modem reconnect .. r7800 looses abilty to give internet .. dns stays the same ip of r7800 stays the same .. nothing changes .. just maybe outer IP from ISP .. routers is 192.168.1.1 modem is 192.168.5.1 .. router gets 192.168.5.47 ip from modem ..fw is up to date
  • I have installed Voxel fw .. same as netgear but newer versions .. I dont think that made it much better
    But I have added is 3rd DNS server in router settings .. I have two Googles and 3rd is modem 192.168.5.1
    and now after modem reconnect I still have internet .. but delay on page load is few seconds, noticable .. so I guess router uses 3rd dns, modem address .. after I reboot router I have much faster load of web .. there is no pause on load .. starts to load after 1 sec ..
    hmm .. that is what I have now .. really puzzled ..
  • update
    today again same thing .. on modem reconnect no internet
    BUT
    on iPhone that is connected to R7800 some apps have internet after reconnect
    like TuneIn Radio and Facebook app, Whatsapp .. others like web/safari, mail, gmail do not work .. I hope this helps ..
    • pec967's avatar
      pec967
      Luminary
      My guess is that this has something to do with your "double-NAT" configuration. I would either change the configuration of the modem/router to modem-only, or change the R7800 to AP mode.
      • mrezrider's avatar
        mrezrider
        I also think something about NAT, disabled NAT/UPnP on modem.
        Netgear support wrote to find MTU .. and I think mine is 1460, so I set that up.
        modem works as a router also .. but is ISP special fw .. very few options to set ..
        I will try to turn off what I can on modem .. and keep R7800 as router
        set R7800 address as DMZ on modem
        turned off all firewalls on modem
        kept DoS protection ON on modem
        set MTU 1460 on R7800 (modem doesnt have that option)
