BryanSD's avatar
BryanSD
Apprentice
Mar 13, 2016
R7800 MU-MIMO - Any advantage to disable?
The Nighthawk X4S (R7800) gives you the ability to enable/disable Wireless MU-MIMO. Assuming a person has no MU-MIMO device, is there any advantage to disabling this capability with regards to router performance?
    • BryanSD's avatar
      BryanSD
      Apprentice
      Thanks NightOwl. With no one else diisagreeing with you, I'll take your answer as the answer!
