RMinNJ
Sep 21, 2017Luminary
R7800 new firmware link broken
I see there is new firmware out.. wanted to try it; 1.0.2.36
http://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.36.zip
But the link above from the firmware download page says file not found.
The link is now fixed.
- RMinNJLuminary
Support told me to use the routers auto update instead of the link to the file. ..until they can fix the link. This worked.
Unfortunately the new firnware did not solve my UPnP received bits per second counter problem.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware. First note down the settings – screen grabs can help here.
- RMinNJLuminary
I'll try a factory reset when I have time.. NetGear support did not instruct me to do so.
I assume a factory reset puts back the factory password? I most certainly will give it shot.
I'm a bit suprirsed at the amount of work needed to report a bug.. Its like I have to try all kinds of tests for NetGear..but they could easily reproduce it themselves (if they wanted to) I don't think its the hardware... ..it seems like a minor but consistent bug in the UPnP counters...when the recieved counter gets to 4GB its stops, and UPnP bits received stays at 4GB.
I know third party firmware probably has the ability to report the current WAN port throughput and no UPnP is needed. I just hought I could report the bug and get it on the fix list. (I had posted the idea in the enhancement/ideas forum that it would be nice
if it could report the current recieved/transmitted bits/sec on the WAN port.)
