skyone
May 13, 2025Tutor
R7800 Readyshare doesn't work on Windows 11
I have two Netgear routers. One main R7800 and the other R6400v2 connected to it via patchcod operating in AP mode. Both are connected to 2.5" drives via USB. On Win10, access to the USB drives is pr...
- May 22, 2025
Solution that worked: reset both of the routers to the factory settings and reconfig them. Disk mapping started working.
skyone
May 22, 2025Tutor
