svr2000
Apr 19, 2026Tutor
R7800 reboots in AP mode
For a long time my R7800 was working fine in normal mode. Recently I got a firewalla and then put R7800 in AP mode . if I do that, the system stays on only for a few minutes and then reboots....
svr2000
Apr 19, 2026Tutor
WAN port is not connected as it is in AP mode. It is set to get IP from the router via DHCP.
- FURRYe38Apr 19, 2026Guru - Experienced User
WAN port connection to the host router is required on all NG routers for Router OR AP mode.
- StephenBApr 19, 2026Guru - Experienced User
Then try connecting the WAN port to the router instead of one of the LAN ports.
