Otch
Dec 27, 2025Aspirant
R7800: Reset password text gets automatically changed (MAC)
Hello, I own an R7800 and recently my admin password was not accepted. I have reset all parameters using a safe password from apple password manger and confirmed the security answers for the passwo...
Dec 27, 2025Guru - Experienced User
Are you actually factory resetting? Or just using password recovery?
I'd try a full reset and reinstall. Push and hold reset for 7-15 seconds while powered on.
Then reinstall without using a backup configuration.
Otch
Thank you plemans but it does not work as mentioned just above.
