Thisjustin5
Nov 12, 2020Aspirant
R7800 restarts
Nitehawk x4s R7800 frequently restarts.
It will lose connection wired and wireless, power light goes amber, and it will boot up and connect without me doing a thing.
I've read thru old, closed post. I've tried it with the latest firmware, I've rolled back to older firmware. I've factory reset a million times.. I've tried it on AP mode and router mode.
Seems if I factory reset it will work fine for a week or so then start crashing again.
Warranty is up.
I'm at the point of just trashing this thing and staying away from netgear with my next purchase. This is literally my last effort bc I don't know what else to do with it.
Any help is appreciated. Thank you.
Warranty is up.
- JayboHApprentice
Did this start after upgrading to .76?
- Thisjustin5AspirantIt's been happening for months and becoming more frequent. I'm not sure if it started w/ the .76 firmware I thought the modem/service was the problem only became aware of the router issue in the last month or so.
I rolled back to .46 firmware which was recommended and it was fine for a week or so then same thing.- canepaTutor
In my case reverting to version 1.0.2.68 solved the problem.
You can read more here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7800-Firmware-1-0-2-76/m-p/2007947
