shade1989's avatar
Oct 15, 2017
R7800 stops showing bandwidth usage for devices
When I'm checking my "Attached Devices" it does not show the bandwidth usage from any device, even if the device(s) are using the internet. I have "Enable Auto Refreshing" checked. The only way for m...
  • JamesGL's avatar
    Oct 18, 2017
    Hi shade1989,
    Did it work prior to upgrading the firmware?
    Try to reset the router to default and reconfigure.
