Arcticcatf7's avatar
Arcticcatf7
r7800 will not connect to internet
I'm trying to set up my new router and when going through the set up the internet light turns white. I then go in and try to set it up on either my hard wired computer or from my phone and it goes to...
  • Arcticcatf7's avatar
    Arcticcatf7
    Dec 26, 2016
    I just did a bunch of searching Charter internet not working for new router and found a solution. Turn everything off and restart the modem. Then press and hold the router power and reset buttons at the same time. Allow it to do its thing then the interent came up and is working prefectly now. Was able to go through the router set up and finsih it.
