jim_0's avatar
jim_0
R7800 with vulnerable Netatalk detected by nessus scanner
did a nessus scan on my internal network and the only critical vulnerability is on my router netatalk version, how do i remedy this?
CRITICAL
Netatalk OpenSession Remote Code Execution
Description
The Apple Filing Protocol (AFP) server running on the remote host is affected by a remote code execution vulnerability due to a buffer overflow condition when handling an OpenSession request. An unauthenticated, remote attacker can exploit this issue, via a specially crafted message, to execute arbitrary code.
Solution
Upgrade to Netatalk 3.1.12 or later.
See Also
    • microchip8's avatar
      microchip8
      Master
      You can try installing Voxel's firmware. It's stock with optimizations and bug fixes. I don't think it suffers from the Netatalk issue
