dogpilot
Oct 03, 2026Follower
R7850 missing Wireless Bridge mode
AT&T decided to cut off my landline. They politely sent a letter stating that disconnect was scheduled for the end of October. And they've stopped providing repair service on landlines. In doing s...
wcalifas
Oct 03, 2026Prodigy
If you're waiting to make it a wireless access point all you have to do is turn off the dhcp and connect one of those 4 LAN ports to the starlink router and you'll have the r7850s wifi working with that system. You won't be able to use the LAN ports as ethernet ports though which is what I think you're trying to do.
