DryHeat's avatar
DryHeat
R7900P Date/Time Incorrect
Router type:  R7900P
Firmware Version
V1.4.3.88_1.3.50
My current date and time are incorrect.
Start Date/Time: Monday, 01 Dec 1969 00:00
Current Date/Time: Wednesday, 31 Dec 1969 18:26
Even though I have just restarted it.
  • have you tried changing the ntp server?
    Or checking the settings?
    Not 100% sure if that device has it as i don't have one but if it does, it'll be under the advanced tab---->administration---->ntp settings
  • plemans's avatar
    • DryHeat's avatar
      DryHeat
      Thanks for the prompt suggestion.  Apparently I'm no longer able to connect to pool.ntp.org.
