OldBob
May 15, 2025Luminary
R7960 Firmware update
Is there ANY possibility that Netgear will put thru a FIX for the R7960 router not being able to update its firmware? Mine has never worked and the links for a work around are well beyond my abiliti...
May 15, 2025Guru - Experienced User
Most likely no. The R series model of routers is getting up in age and maybe headed to EoL.
Might have someone with more experience in your local town to help you with getting it updated if you really need it updated.
