OldBob
May 15, 2025Luminary
R7960 Firmware update
Is there ANY possibility that Netgear will put thru a FIX for the R7960 router not being able to update its firmware? Mine has never worked and the links for a work around are well beyond my abiliti...
OldBob
Can you please post me a link to that workaround that you are referring to? Maybe if I go slow I can try but afraid I will loose any existing function of my router if I do something wrong.
- FURRYe38May 15, 2025Guru - Experienced User
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000P-V1-4-1-50-Update-workaround/m-p/2248802/highlight/true#M219856
See if you can find a friend or family member to maybe help out as well.
- OldBobMay 23, 2025Luminary
Thank you..cant find someone to help so I guess I will just have to keep using it as it is..is IS working - just frustrating..thank you for all your help.
